Did a little sanding on the nacelle/strake joint where we put a layer of micro balloons. Put a loyer of epoxy on the inside so it would start getting sticky in prep for applying the 5 layers of glass to create the flange. Applied the 5 layers of BID one at a time to create the flange. Did some finish work on the nacelles.
