RV-12
Date:  1-20-2014
Number of Hours:  10.00
Brief Description:  Smoke Unit
Smoke on!!! ;-)
Installed a smoke unit from www.skysmoke.com
Installed the tank behind the seats.
Oil line goes initially to a solenoid, thereafter to the pump. Line follows its way to the right side off the cockpit. At that position I used a quick disconnect fitting. Switch is above the Skyview panel. 18 Gauge wire runs through the center and the gear channel ending in a molex connecter.
I can take out the smoke unit in a few minute now.
quick disconnect
quick disconnect
