Removed the intake manifolds. Removed the coolant sockets/hoses/expansion tank. Removed upper grounding lug from the starter. Trimmed to the scribeline (innerside) and painted red (high temperature paint) the cooling shroud. Installed engine mount ring, used loctite 243 and torqued the M10 bolts 40Nm/360inchpound (see page 28-03 Illustrated Parts Catalog). Riveted the drip pans and sealed the corners with proseal.
