Brief Description: 35 - Landing Gear & Engine Mount
35-02 step 2: Installed upper engine mount. I did put an extra washer under the head of the bolt (Bolt was a bit long). 35-06 step 2/6: Greased the nosegear leg with Aeroshell #5. Torqued the nosegear nut and drilled #30 the nosegear leg for the cotter pin.
