RV-12
Date:  3-8-2010
Number of Hours:  6.00
Manual Reference:  29
Brief Description:  29 - Fwd Upper Fuselage
Chapter 29 is about the FWD Upper Fuselage.
Took quite a bit of time to complete page 29-02.
Did most of the "construction" work for this chapter. Still have to do the F-1240 upper skin and the mapbox.
At the canopy ribs and the oil tank brackets you have to dimple #30 some holes. The structure behind needs to machine counter sunk. I initially countersunk with a 100 degrees bit but that results in a not so good fit. The 120 degree bit does the job better (see also page 14-02 stub spar assembly).
Did the 1/4' holes with the reamer (canopy & strut attach holes).
I still need to debur all parts.
29-02 step 5
29-02 step 5
29-04 step 4
29-04 step 4
29-05 step 1
29-05 step 1
