Brief Description: 27 - Rudder Pedals & Brake System
27-02 All steps 27-03 steps 1/7
I used the bandsaw to split the rudder blocks. Wrong AN315-3R nuts delivered by Van's. Powdercoat was removed by Van's at the wrong place. Used sand paper to remove powdercoat at the correct place. Used a reamer to final drill the 1/4 holes in the brake pedals. Attached the master cylinders. The bolts which attach the cylinders to the assembly were initially to tight. Had to cut the cotter pins. The bolts can be turned by hand now. Ordered some new cotter pins (together with the auto-pilot kit).
