RV-12
RV-12 120209
35 - Landing and Engine Mount
Completed SB 12-09-26 Loose Attach Bolts.
Drilled the 3/8" holes in the bottom skin.
Removed the AN6-24A bolts and replaced by AN6-23A bolts.
Chamfered the landing gear brackets. Installed everything again and torqued the bolts.
RV-12 120209 Home
1019
00 - Miscellaneous
05 - Paint
25
116
06 - Vertical Stabil
07 - Rudder
08 - Anti-Servo Tab
09 - Stabilator
10 - Tailcone
11 - Empennage Attac
12 - Empennage Fairi
13 - Spar Assembly
14 - Rear Spar
15 - Wing Ribs
16 - Stall Warning
17 - Wing Skins
18 - Flaperon
20 - Center Bulkhead
21 - Mid Fuse Ribs
22 - Fwd Lower Fusel
23 - Side Skins
24 - Rollover Struct
25 - Tailcone Attach
26 - Seat Backs
27 - Pedals & Brake
28 - Fuel System
29 - FWD Upper Fusel
29 - Fwd Upper Fusel
30 - Wing Attachment
31 - Fuselage Wiring
31A - Wing Elec Upda
32 - Flight Controls
33 - Miscellanea
34 - Canopy Installa
35 - Landing Gear an
36 - Gear Leg & Whee
37 - Fuel Tank
37 - Fuel Tank SB
38 - Cowling
39 - AP Servo Bracke
40 - Lighting
41 - Interior Option
42C - Skyview D1000
42D - Skyview Update
42F - ACK E-04 ELT
43 - Dual Display
44 - AP74 & AP Servo
45 - Firewall Forwar
46 - Engine Installa
47 - Spinner & Prope
49 - Cooling System
50 - Engine Controls
52 - Towbar
First Flight
Flight Reports
Modifications
Smoke Unit
