JOE'S WEB SITE
Zodiac 601 XLB
Mounted HS to fuselage.
Aligned HS. It appears to be perfectly center. Also appears to be perpendicular with the fuselage centerline. However, the measurement from tips to center in cockpit area is off by about 15 mm. Since 20 is allowed I guess that will be OK.
Zodiac 601XLb Tail Dragger Home
Zodiac 601 XLB Home
2059
Airframe
Auto Pilot
108
Brakes
131
Control System
Cowl
76
Entire Plane
678
FWF
Lights
117
Paper Work
Pitot/Static
Post Const Insp
Propeller
Spinner
Upgrade
214
Wire
Work Bench
