Brief Description: Removed Lower Engine Mount & Install Cabin Heat Ca
Riveted Cabin Heat box. Installed a eye bolt to attach a spring so that valve is sprung to both closed position.
Cut the engine mount bolt off in front of firewall and removed the engine mount that attaches to aircraft lower longeron. Needed a longer bolt to allow shim for proper engine angle.
