Drilled 17/64 hole in horizontal stab at spar Installed a 3/16 nut plate Installed a 3/16 eye bolt with lock nut and lock tite Drilled 3/16 hole in elevator bellcrank Installed two small s-hooks in hole above Installed 7 #64 rubber bands between eye bolt and nut plate Approximately balances elevator.
Photo 1 & 2 self-explanatory Photo 3 is the amount of trim required for level flight.
