Brief Description: Check on some electrical issues.
Looking for intermitten trim operation from pilot's stick. Nothing definite but it is working now.
There is a center off rocker switch for strobe and nav lights. Both light when switch in either postion of the on positions. I disconnected the connector to strobe power supply and the positive wire reads 11.1 volts when switch off, with Nav on it reads 11.9 volts and with switch on strobe it reads 12.2 which is the full battery voltage. I left that connector off until I can have time to locate the issue and fix. Not needed as I will not be flying at night during phase 1.
