Brief Description: Removed splices by replacing with new one piece wi
6/10/2015 Tach Time: 165.87 Total Time 695.9
R/R the fuel line clamp with a screw band one as I could not find the proper machine screw for the one that was missing. Replaced the fuel pump spliced wire with new 16 ga wire and installed a new inline blade type 3 amp fuse nearer the firewall. All connections wire soldered and insulated with labeled heat shrink.
