Brief Description: Repair oil temp sensor that failed inspection
During 2018 condition inspection it was discovered that oil temp sensor has improper lock nut. Also, internals rotate when trying to remove nut. Removed sensor. As an oil leak is impossible due to the design, I decided to secure internals from rotation and reuse with a proper nut, star washer and blue Loctite.
