Brief Description: Reinforced main landing gear mount.
12/20/2015 Tach Time: 188.58 Total Time 718.31
Landing gear mount 6B11-4 has bent flange and attached radius plate. Removed plate and fabiricated an 1/8 inch steel angleas doubler at bolts welded to mount. Replace centering blocks with 1" thick 6011 aluminum which allows 7/8 inch thick landing ger to float within defined area.
