Brief Description: Installed New Wheels and Brake System
Drilled landing gear strut and new axle on left side. Had to align axle to strut with the proper toe-in. Inserted key in axle and slid caliper over axle. Could not put caliper completely over the key because brake line compression fitting is hitting the strut. Need to find an elbow to move fitting up and away from strut.
