Drilled mount screws for Lord mount on engine mounting plate. Drilled holes in second mounting "L" bracket for holes for mounting engine mount to square root tube and mounting holes to attach mounting plate to "L" brackets through Lord mounts. Turned engine upside down, attached engine mount to engine, and positioned on rear of fuselage. Need to modify fuselage to allow placement of electric starter. Need to find out if oil pump can be turned upside down. Need to figure out where to mount the oil tank and avoid prop and control surfaces.
