Brief Description: filtered air box and throttle bracket
Talked to Don at Airflow Performance about availability of a factory bracket for throttle and mixture, he has a bracket but would need extensive cutting and modification as it is made for a tail dragger, and nose gear engine mount has additional weldments that would be in the way. Ran an idea by him about modifyiong the Vans carb bracket that they sent, cutting the ears off and mounting it upside down as a platform for angle brackets to hold the cables. He thought it would work and said he thought he had seen that done before..so....cut the ears off and mounted it up. I think it will work.
More trimming and fitting of the FAB, getting close.
