Brief Description: final windscreen prep before bonding
More cutting, trimming and belt sanding to get the fit just right. Devised a clamping plan and rehearsed it so as not to stumble when adhesive is applied and canopy installed - no second chances. Primed the fuse and roll bar, then installed black suede dash covering. Drilled a couple holes first for AOA and a GPS puck on top of the dash.
