mapped out and documented all VPX input and output pin assignments as well as standalone wire conenctions that will need to run through a CPC connector. Ran and documented a load analysis; 60A alternator is just big enough, and we will use every single output (assignable circuit breaker) pin on the VPX....this is a high tech machine!
