prime and rivet servo brackets, dimple cover. Install elec. pins, trim hole opening for correct rod clearance. I temporarily rigged up an indicator and battery to find neutral, then cut rod and installed clevises. Ran full up and down, checked for interference and proper clearance plus full trim tab movement - all good! Substituted SS screws for cad plated.
