initial trim and fit of wing tips. They fit pretty good, some fill will be needed on both at the leading edge which is typical. Aligned both with aileron trailing edge in neutral, then matched trailing edge profiles with belt sanding of the fibergalss tips. Cut holes in 916 ribs per plans and started installation of those. Next steps rivet ribs in and then install nutplates all the way around.
