worked on a few issues: fixed oil temp sensor leak with new nylon gasket Completed backup battery test reprogrammed trim speed threshold to speed up elevator trim below 100kts Set flap operating threshold to 90 kts or less Changed Skyview setup to enable autopilot control panel (was just working on big screen only) Turned off AOA audio until we can get that system calibrated
Installed new Earthx LifePo battery and battery box. Installed nutplates in box for firewall and cover mounts and powdercoated it gloss black. Installed charge cord access in oil door area.
