Joe & Steve's RV9A Project
Date:  7-26-2017
Number of Hours:  2.50
Brief Description:  install AOA probe
cut AOA probe plate to match inspection plate, drilled and dimpled. Decided to use center plate location in order to avoid conflict with aileron linkage in outboard plate location. Rerouted heat wire and tubes, terminated wires and installed a ground lug in a rib.
