I finished installation of the Header Tank. I ran 5/16” rubber fuel lines (as required by the Viking engine installation instructions) from the rear spar attach point to the header tank. I included a fuel filter on each fuel line between the wing fuel tanks and the header tanks. I installed the drain line and sump valve on the bottom of the fuselage. I’m going to wait to install any more fuel lines until I receive the fuel pumps.
