Brief Description: Aileron/Flap Hinge Bracket Fillers
I let the resin set up overnight. I cut off the excess balsa flush with the top and bottom of the hinge plates with an oscillating saw. I coated the exposed balsa with resin to seal the wood. After the resin has set up I’ll give it a light sanding to take off the shine.
