Johns Web Site
Date:  8-15-2014
Number of Hours:  6.00
Manual Reference:  Ch 3.26
Brief Description:  Sand/Drill Rib Caps
I sanded the wing ribs to remove rough edges and splinters as well as to smooth the transition to the spars. I also drilled holes in the rib caps for the fabric rivets (to be installed later). The template used to mark the hole locations came with the kit. I think Gary picked it up when he was at the factory.
