Since the last log entry, I’ve spent multiple days working on the wiring. I went as far as I could with the panel without the radio and GPS installed. I took the panel out of the plane and removed all the switches, fuse box and wires. I cut the hole for the Engine Information System. That took quite a while since it was an odd shape and it had fairly tight tolerances between the opening and the mounting screws.
