I installed the small plate (F2740.0) and bracket (F2760.0) to the left elevator. This bracket is used to attach the elevator trim control cable in front of the trim tab. I fitted and drilled these parts earlier. The plate was bare aluminum stock so I primed it . The bracket was powder coated by the factory. I installed the parts with SS rivets per instructions in the manual. I coated the rivets with Aerograde joining compound during to assembly.
