I sanded the wing ribs to remove rough edges and splinters as well as to smooth the transition to the spars. I also drilled holes in the rib caps for the fabric rivets (to be installed later). The template used to mark the hole locations came with the kit. I think Gary picked it up when he was at the factory.
