Brief Description: Horizontal Stabalizer Front Spar
Collected parts and started on Front Spar for Horizontal Stabalizer. Mated parts together, and then drilled inside holes to #30. Confusing point with one hole. Instruction manual says to drill "ALL" holes inside the rib attach point, but the plans show one of the holes must wait until fuselage assembly. Will check the boards. Spend a lot of time using a Scotch-Brite Wheel to trim HS-814. Finally got it, but it took forever and a large chunk of the wheel is worn away now. Will try using the bench sander for HS-810 this afternoon. Overall good night. Worked until 1am at the hangar. Tried to take a picture with me in it for better documentation (learned that at Oshkosh), but the camera battery died. Hence, only one pic for tonights efforts.
