Baby Steps to an RV-8
Date:  9-23-2019
Number of Hours:  0.50
Manual Reference:  Sect. 7
Brief Description:  Prepped Right Tank for Pro-Seal
In preparation for riveting the Baffle on the Right Tank I went through the motions of making sure things are good to go. First I inventoried my AD-41 & 42H rivets to ensure I would not be causght short. I had to order some additional rivets from Van's in order not to run out. I then checked both the gas line pickup screen to ensure it was at the bottom of the tank and I also checked the fuel float resistance and placement when full & empty. Pictures included. Last, I went around t oall the sealing surfaces and roughed them up using a gray scotch-brite pad. I will clean things up with acetone when the wife isn't home as the smell can spread to upstairs, especially if using MEK (which I'm done with btw).
I will probably wait until I have a good three or four hour period to pro-seal. Actually, I just remembered that I must order some more plastic tips for my Sempco gun. I might have some at the hangar but if not, it looks like another order to Brown Supply if I rememeber correctly. More to follow, folks. Each time I work in the shop motivation continues to grow. I love flying my previously built RV-6 but the urge to fly something new that I've built with my own hands is always present in my mind.
Float at bottom of tank
Float being held at top of tank
Displaced baffle to check float
