Brief Description: Prepped,Dimpled, Drilled Right Fuel Tank Stiffener
Spend some time getting the right fuel tank ready for riveting and pro-sealing of stiffeners, and eventually the ribs. I scotch-bright scrubbed the stiffeners and the rib/stiffener placements on the fuel tank. Used both gray and red pads along with cleaning using MEK and a degreaser. Cleco'd things in place after dimpling the stiffeners.
Looks like things are starting to come together. I'm slowy remembering where I left off a long while ago.
