Completed riveting and most of the pro-seal of the inboard and outboard ribs. Still must go back this weekend and add Pro-Seal to the outboard rib flang fillets.
Hooked up the vent tube and did my bes to bend it in place.
Must study up on how to instal lthe baffle. Must first install the fuel sender though. That should be fun aligning the rod with the ribs in place.
Almost done...just need to push through this tank. Joe gave me a pressure test fitting from Van's. Will give that a try when I'm done.
