Still working on the platenuts for the wing skin. Just starting to get back into the swing of things after a while traveling and working.
Moved the Right Spar to my garage to keep from working in the cold hangar. Weather not bad right now, but the snow is right around the corner.
Discovered something after taking a step back and looking at the drill patern on the spar. The attach points for the access plates are not common with the platenut holes. I was having a hard time trying to figure out which holes were which.
