Worked for a couple hours trying to figure out how to install the Electric Trim Servo. After reviewing plans for quite a while, it made sense. Instructions are non-existent though, but I understand that's par for the course from this point on.
Started by assembling Servo. Then realized the cover plate holes must be dimpled to accept the 426 rivets. Should have thought about this before. I tried using a rivet gun dimple, but did not have quite enough power to bend the thicker aluminum. I ended up breaking the rivet gun so I had to rebuild it.
Will visit this again, but I'll use the DRDT-2 pull-dimpler. Not sure why that didn't come to mind. Must have been late.
