Just taking it a step at a time. Starting to prep the pieces in anticipation of priming. The skin is already done as you can see in the pictures. That was an ordeal in itself. I used a new paint gun that had not been set up yet. Wow did it spray some paint...thick! I tried to clean the paint off, to no avail. So the only thing I could do at that point was to put the primer on thick and dark. Hence, the very dark green skin for the left side. Oh well, nobody will see it once buttoned up.
Heading back to the hangar in a few hours. Should have more to report later this evening.
