Jeffreys Web Site
Date:  2-23-2006
Number of Hours:  3.50
Manual Reference:  Wings Hardware
Brief Description:  Verify and Update Wings Hardware List
Verified and update wings hardware list, coverted to stainless and added hardware for hinge spacers, bearings and strut brace attach brackets.040 - ANC3-5A Attach Ailiron / Flap Hinges and Strut Brace Attach Brackets to Spars016 - AN3C-6A Main Strut Attach Bracket022 - AN3C-7A Spar Root012 - AN3C-10A A / F Hinge Spacer (Ground Strap Attachment) and Strut Brace Attach016 - AN3C - 12A Ailiron / Flap Hinge Asembly008 - AN3C - 14A Ailiron / Flap Bell Crank Supports to Spars008 - AN3C - 15A Ailiron / Flap Bell Crank Supports to Spars008 - AN4C - 10A Ailiron / Flap to Ailiron / Flap Hinge008 - AN4C - 11A Ailiron / Flap to Ailiron / Flap Hinge( Not sure about grip range for Ailiron / Flap to Ailiron / Flap Hinge will order both AN4C - 10A and AN4C - 11A and see witch will work the best, these bolts will also have tobe drilled)008 - Aluminum 6061-T6 Spacers I.D. 3/16", O.D 1/2" Length .370" (A/F hinges) (Will machine these myself)008 - RULON J Sleeve Type Bearings (Small Parts PN U-SBP-4/8) (I.D. 1/4", O.D. 3/8", Lenght 1/2" I will machine length to .037")016 - RULON J Thrust Type Bearings (Small Parts PN U-TBP-6/12) (I.D. 3/8", O.D. 3/4" Thickness .060")138 - AN3 Stainless Elastic Stop Nuts276 - AN3 Stainless Washers008 - AN310C - 4 Stainless Castle Nuts016 - AN4 Stainless Washers
