Spent some time digging through the my small parts boxes that had gotten boxed up for the move so that I could continue installing the brakes. Finally found the brake cable mounting block.
Got the location set and drilled and bolted it to the bottom of the engine mount as well as aligned and drilled the holes through the firewall for the brake cable. This was much more difficult than I expected. First your trying to drill a vertical hole up next to the angled firewall. Then trying to get a nut and washer on the bolt through the small hole at the bottom of the mount took several tries.
Cable block mounted and firewall pass through holes drilled.
