Mark s Airplane Factory
Date:  4-5-2009
Brief Description:  Drilling the wingtip
Dressed all of the cuts and drilled the tip to the wing. The clecos closed a lot of the gaps much better than the tape, so I suspect once the rivets go in it will get even better.
Now I need some lights. Spent lots of time researching the low weight, low current draw LED models. Will make the decision tomorrow and place an order. I do know it will be a combo light with green/white/strobe and red/white/strobe to eliminate running wire to the tail for a white light.
Looks good without a row of rivets down the center.
