Mark s Airplane Factory
Date:  4-27-2010
Number of Hours:  8.00
Brief Description:  Finish Rudder Pedals & Start Firewall Electrical
Finished hooking up the rudder pedals to the cables and fitting and adjusting the tension on the rudder return springs. I've read that other builders have left off the springs, but I'll give it a try with them. A bit of a pain to get the length right, cut the spring steel and reshape the ends to fit the pedals.
Started the wiring process by marking wires. Using a technique of paper labels printed, 8 point font in Word, cut out and slipped under an appropriate length of clear heat shrink. A little tedious due to the size, but seems to work well.
Rudders springs cut to length, ends shaped and installed.
Wires marked and connectors crimped onto the ignition wires from the engine to the firewall coils.
