Jeff Mitchell's RV8 project
Date:  12-23-2011
Number of Hours:  5.00
Manual Reference:  N/A
Brief Description:  Firewall cable penetrations.
I drilled out the center hole of three firewall penetration kits that I will use to secure the cables for throttle, mixture and propeller pitch. The kits are from Doubletee Products (www.doubleteeproducts.com) available from Aircraft Spruce. I step drilled the final hole diameter to 21/64" one drill size up at a time.
Step drilling one size at a time
Assembly screwed to wood
