Jeff Mitchell's RV8 project
Date:  12-14-2012
Number of Hours:  4.00
Manual Reference:  N/A
Brief Description:  Revised VP-50 retension bracket.
In order to install my transponder right above the VP-50 I needed to change the orientation of the retention bracket from the stock vertical to a horizontal one. I cut, bent and drilled the required holes in some flat stock to accommodate this. Now, I can get to work on installing the transponder.
New horizontal bracket
