Jeff Mitchell's RV8 project
Date:  4-17-2011
Number of Hours:  7.00
Manual Reference:  N/A
Brief Description:  Utility plug rocker switch installation.
I installed and wired a rocker switch to the VP-50 CU. This one switch will tell the control unit to turn on or off the power pins to the utility outlets. I also installed the logic switch wiring to an unused ON/OFF switch on my Infinity stick grip to the VP-50. I don't know what I will use this switch for but if I need it in the future having the wiring in place will make it easier to utilize.
