Jeff Mitchell's RV8 project
Date:  4-22-2009
Number of Hours:  2.50
Manual Reference:  7-12
Brief Description:  Installed right left hand aileron.
I installed the left hand aileron in much the same manner as the right hand one. I used the jig to set the neutral position and installed the pushrods. I used a Delrin rod with a 0.55" O.D. cut to length and drilled a hole for the aluminium spacer to provide a stop for downward travel limit as suggested on several builder logs. It works great.
Both ailerons installed
Derlin down travel limit stop
Inboard pushrods
Inboard pushrods
