Jeff Mitchell's RV8 project
Date:  4-19-2009
Number of Hours:  4.10
Manual Reference:  7-11
Brief Description:  Installed aileron brackets.
I installed the hinge brackets on both ailerons. Then I cut the aileron alignment jigs out of some 1/4" plywood, drilled the holes that line up with the wing rib tooling holes and marked two lines that will be used to find the neutral aileron position.
Aileron brackets installed
Completed ailerons
Completed ailerons
