I mixed up 20 grams of tank sealant and completed the installation of the sender and fuel pickup to the access plate. Using a little EZ turn lubricant I installed the access plate using stainless steel screws and washers. Then I attached and sealed the sender power and ground electrical leads. I also did some more countersinking of the main spar span wise rivet holes.
