Brief Description: Sealed right tank span wise shop heads.
I found the anti-rotation bracket prevented the fuel pick up tube AN elbow fitting from sitting flush on the access plate so I fabricated a thin spacer to rectify this. Then I mixed up a glob of tank sealant and applied a swirl to the shop heads of the span wise rivets at the rear baffle to skin joint. I finished up by doing a few more countersinks in the main spar.
