Jeff Mitchell's RV8 project
Date:  10-5-2008
Number of Hours:  1.30
Manual Reference:  7-8
Brief Description:  Pressure tested the left hand fuel tank.
I cut the end off of a balloon and slipped the fuel cap into it to improve its seal. Then I attached the fittings that came with the test kit from Van's. I used my bicycle pump to slowly add some pressure to the tank until the balloon on the vent line inflated. I used soapy water in a spray bottle to check for leaks. I only found a single tiny leak where the most inboard Z-Bracket meets the aft baffle. If I had to have a leak I guess this is about the best case scenario for its location. It's only an inch from the access panel. I plan on thinning some sealant and using very slight vacuum pressure to draw it into the hole. If that doesn't work then I will remove the access plate and do it from inside. By the way, it looks like the ‘faying’ method of sealant application works, and its way less messy.
Van's tank test fittings installed
Tank pressurized
Tank pressurized
One small leak at inboard Z-Bracket
