Jeff Mitchell's RV8 project
Date:  8-30-2008
Number of Hours:  4.50
Manual Reference:  7-6
Brief Description:  Fuel sender doubler, fuel cap and low point drain.
I finished off the fuel sender installation in the second bay by setting the rivets securing the nut plates to the reinforcing doubler plate. Then I drilled 4 holes into the T-410 reinforcing plate for 470AD-4 rivets for the tanks most outboard ribs (left and right hand tanks). Then I used a couple of small C-clamps to position the left hand fuel cap in place and back drilled the holes. Then I did the same for the low point fuel drain. I ended the day by removing the vinyl along the rivet lines on the left hand fuel tank.
Fuel sender doubler plate installed
Fuel cap drilled in place
Low point fuel drain point
