I re-installed the aileron bellcrank assembly onto the left wing main spar so I could determine the best location to mount my pitot tube mast. I decided on the rib bay just outboard of where the bellcrank is mounted. I have to route the pitot/static lines between the bellcrank and the spar itself to avoid some fairly sharp turns in the lines. Even though the lines do not rub on the bellcrank I plan on securing them to the main spar at that point with some nylon tie straps.
